gutfelt wrote:
DH1644 wrote:
Hi I have a 1990 Fleetwood Southwind and the water heater seems to be functioning but when I turn on the faucet it runs hot for a few seconds at best. I googled it and looked for valves that control it coming into the rig and the only ones I found are near the outdoor shower area. Two are drains and one is to fill fresh water tank. I have also “ burped” the relief valve which released very hot water. I’m at a loss. Any help appreciated!
when u say runs hot for s few seconds does it still have full water flow? if so on some MH systems if the outside shower tap is left on with the shower head off it will limit the hot water supply to the interior sinks
also make sure the WH winter bypass valve is fully in off position
It runs full force. I can’t find a winter bypass valve so not sure where else to look
