Old-Biscuit
Oct 06, 2020Explorer III
I posted in your 'other' thread but is got closed
Here is the info concerning your Mixing Valve
**Highly doubt it is due to tank...tank is Aluminum with a Zinc Cladding
Your issue is build up of Scale/calcium
Need to do a Vinegar Soak
2 parts Vinegar to 1 part water...FILL water heater via T&P Relief valve (remove add solution reinstall)Then allow water heater to go thru 4-5 heating cycles
*Let it run overnight
Then drain/flush crud from tank thoroughly
