Baja_Man
Nov 28, 2016Explorer
Water heater not operating & City water issues
I used my rig last week for five days. Two issues occurred that need my attention:
1. Water heater would not fire up under 110V nor 12V operation. The 12V did fire up and then after a few minutes shut down. Needless to say, we made it without the use of hot water using the campground showers.
What shall I look for to solve this dilemma?
How can I use a process of elimination?
Where do I start?
2. When using city water, the overflow line from the freshwater tank began to leak/dispense water as it does when fresh water tank is full during filling process. I moved the city water lever to directly vertical (for city water operation) instead of past vertical which lever will do, and it appear to stop the overflow. As far as indicator gauge/light, fresh water tank did not fill. Is it possible that city water filled fresh water tank and then overflowed? How can this be if lever was not positioned to fresh water fill?
What might cause this?
Thanks
Where do I start?
Thanks
