Old-Biscuit
Apr 22, 2015Explorer III
Jopopsy wrote:Mich F wrote:
I'd suggest you get acquainted with your owner's manual, which in the case of Winnebago/Itasca is quite comprehensive. They copy the literature from the manufacturers of each component, and add it to their manuals. More than likely your water heater is gas only.
From the specification page on the Minni Winnie web site you have a
6-gallon LP water heater w/electronic ignition
RE: manual - yep
RE: Gas only - yep
Just curious, What is your definition of 'manual' ?
The 6 gallon propane w/electronic ignition is turn switch ON and WH will self ignite, heat water, turn off when temp reached and refire when temp cools down......only manual thing about it is ON/OFF switch
