et2
Jun 11, 2018Explorer
Water heater problem diagnosis
We have a Atwood water heater in our 2013 fleetwood expedition. Recently I've experienced intermittent operation. It would light and run for a few minutes sometimes longer and shut off. I know it didn't run long enough to heat the tank as we just arrived to the campground.
Sometimes it put a red fault light, but not always. The odd part was if the cover was down it would light. Then I'd put the cover up and latch and it would shut off. This happened numerous times. If I opened the cover back up and tap the igniter wire it would click and fire-up, but shut of if I put the cover back up.
But after playing around a few times resetting it , then it would run as normal. I do need to run a brush through the gas tube and burner. But if there was debris in there it wouldn't stay lit at all?
Thermostat, circuit board, thoughts?
