Jeff1953's avatar
Jeff1953
Water heater question
I have a 2005 Itasca Suncruiser 38R. I noticed that I had a leak in the supply line behind the water heater. In the process of removing the water heater, I accidentally broke some of the Styrofoam that surrounds it. I'm thinking of just going ahead and replacing it, since it's dated 2002. Before I do, however, I was wondering what material they use in the water heaters? Is it aluminum? If so, I may not need to replace the entire unit if I can repair the Styrofoam. I may go ahead and replace the electric element if I decide to keep it, to avoid having to remove it again in the near future. the model is Atwood GCH10A-4E. It has the heat exchanger built into it. Has anyone done this or is it just better to go ahead and get a new unit? Thanks in advance.
