King mattress..mildew problem
Ripping carpet up
Now water heater......leak and area stinks
Whew..sounds like you have some issues and lots of work
The water heater is removed from outside.
Inside you have to disconnect the hot out and cold in lines at fittings on tank
Have to disconnect wiring........may be a junction box or two on sides of tank, may have electric element wiring on back....just depends on make/model
Identify AC breaker and DC fuse for WH and turn off/remove
Propane has to be disconnected..
Outside frame screws removed then water heater can be pulled out.
Have fun...work safe!
