- bobthegodExplorerCheck this out....
https://www.youtube.com/watch?v=IsiXaMEneaY - rambler2011ExplorerCheck your heater bypass valves
- carz57rExplorerThe the burner comes on,doesn't make the water warm
- darsben1Explorerthen the thermostat if you hear the burner come on. IF burner does not come on either control board or gas valve
- carz57rExplorerGas water heater,the outside shower is turned off under the sink
- bdpreeceExplorer IIIf you have an outside shower, make sure it is turned off at the faucets. The hot and cold will mix if it is only turned off at the head.
- darsben1ExplorerPerhaps a little more information. Like on gas or electric. Do you see or hear the burner ignite. Have you checked the thermostat do you have an outside shower and could one of the faucets be open with the shower head off this might allow bypass.
38,778 PostsLatest Activity: Jun 10, 2026
