bobman
Oct 10, 2014Explorer
Well I tried that trick with lighting the range burner first and the water heater fired right up. So thanks
and the pilot light is now on so if that's all I need to keep it warm I am good to go.
After the heater started (it has piezo starter not manual) the burner was running full blast and I turned off the switch on the wall after running it for about 4-5 minutes. The pilot stayed lit.
DO these things have a thermostat on them to shut the down at 120 or whatever the set point is or must it be shut down manually? I cant imagine there's no thermostat, but I would rather ask a dumb question than find out the hard way.
Thanks for the help I don't have any documentation on the water heater to refer to.
