bobman
Oct 12, 2014Explorer
Old-Biscuit wrote:
Take it that the normal t-stat was not opening and that the water was getting very hot until ECO t-stat opened.....correct?
Just remember.....if ECO should fail to open it will continue heating until the PRV (press/temp relief valve opens) at 210*F/150# and it will blow very hot steam out of valve.
Point is.......exercise the PRV at least once a year via lever with water supply on to blow out valve seat of any build up/debris.
Yes that's what happened the ECO did function though
I'll do that with the valve thanks for the tip
