bsandy56ExplorerOct 13, 2015water heaterI have a atwood 6 gal. mod. # gga-be. I want to drain to winterize. It has a drain plug with two wires in it.Is it safe to take that plug out? Never seen one like that before. Could I drain with air p...Show More
Dutch_12078Explorer IIIOct 13, 2015Disconnect the wires and pull it out. You'll find there's an electric element on the other side of the plug, likely from a Hott Rod electric mod kit.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
