OK I need some help with the electric and propane switch . Where do I start to check why the switch doesn't light up. First of all the electric water heater is working just fine except for the light. ...
It is NOT supposed to light up. It will only come on if it does NOT ignite on propane. To check on propane turn off the electric heater for a day and then turn on propane only and it should ignite.
