OK I need some help with the electric and propane switch . Where do I start to check why the switch doesn't light up. First of all the electric water heater is working just fine except for the light. ...
As you said the electric water heater is working just fine except for the light. The bulb in the switch is burned out...This is very common. Easy fix, replace the switch.
The propane water heater should not start if the tank is full off hot water,,,,, heated by the electric heater element.
