OK I need some help with the electric and propane switch . Where do I start to check why the switch doesn't light up. First of all the electric water heater is working just fine except for the light. ...
Removed the panel and found purple wire disconnected from the propane switch and now that light is working. Would that keep WH from lighting up on propane?
