Tande12506ExplorerJul 08, 2017Water heaterI have a 10 gallon Surburban heater that does not heat the water as hot as it does on gas. Showering on electric only only requires the hot water valve to be opened. When on gas it operates with both ...Show More
Tande12506ExplorerJul 08, 2017Thank you for the quick reply. I was hoping that there were two thermostats.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
