I have a 10 gallon Surburban heater that does not heat the water as hot as it does on gas. Showering on electric only only requires the hot water valve to be opened. When on gas it operates with both ...
Just be very careful when changing them. The wires are routed behind the sheet metal face and the edges are very sharp. Cutting the wires is easy to do.
