The electric side of the water heater isn't working. This happened once before and the dealer put a new element in it. I'd like to do it myself and I'm sure someone here has done it. How hard is i...
If it is a Suburban water heater the heating element socket size is 1 1/16”. Available at auto parts stores. If Atwood water heater I don’t know.
But the problem could also be a number of other things such as tripped breaker, bad switch, bad thermostat/high temp cutout, bad/loose/burned wire connection, bad 12v/120v interposing relay, ....,,.
