The electric side of the water heater isn't working. This happened once before and the dealer put a new element in it. I'd like to do it myself and I'm sure someone here has done it. How hard is i...
Electric elements are 1 1/2" ....Atwood, Suburban, Residential etc Thin wall on element flange so standard sockets tend to slip. Element Wrench works pretty good when you have direct access...thin wall, flat sided
(1 1/16" is for the Suburban Anode Rod)
What brand/model is your water heater---cause unless you turned element on w/o water in tank it probably is something else wrong
