sg47619ExplorerJan 14, 2022Water heaterI have purchased a2001 Monaco Dynasty Jack DS the manual says to drain the hot water heater can’t fine the darn thing. It dose have the Aqua- Hot system.
sg47619ExplorerJan 14, 2022Thanks, I’ve never had a Class A before cannot believe you don’t hace to drain the water heater. From Southern Indiana.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
