pappaoneExplorerJun 12, 2015water in batteries boilingI went to check the batteries in the MH two 6 volt and when I removed the filler caps noticed the water was bubbling (boiling) what causes this and what do I need to do?? Thank you
wolfe10ExplorerJun 12, 2015Yes, it COULD be overcharging. Check voltage. Float level (after the batteries fully charged should be 13.2-13.5 VDC). ORIt could be a bad cell on a battery.A perfectly good charger putting out 13.2 VDC into a battery with a dead cell (i.e. a 10 VDC battery)WILL BOIL THE BATTERY.
