bobndot
Oct 16, 2021Explorer III
Could be many places for a leak. Depending how the unit is sitting , water will travel on a slight horizontal plane then seek its lowest point.
Slides are a PIA. At 11 yrs old you need to check a lot of things.
Best way is to read owners forums . Try to find info on the manufacturer of your model. Check youtube for visual inspection ideas. The ratchet side rails can help you ID your slide. Try vegetable dye in the water to trace a leak.
Check for dried caulking around clearance lights.
Not all window and slide cutouts at the factory are performed perfectly. I had a router go off its mark creating an indentation in what should have been, a straight seem. The factory filled the void with a glob of sealant which held up for two years before non stop leaking occurred.
The leak source was passenger side front roof. The leaking water found its way to the drivers side rear low point compartment.
I traced water stains and rusted metal parts to find the source with help my friend who owned the dealership. But we had to dissemble a lot of the rv to find it. Lucky for me, he picked up the tab.
https://gdrvowners.com/forum/operation/slides/27691-schwintek-slide-leak
38,783 PostsLatest Activity: Sep 21, 2026
