MrChuckles
May 06, 2013Explorer
Water leak from fridge
We are in our second week in our 2008 Monaco Knight. The fridge has begun to leak or make condensation (don't know which) that allows about 1/4 cup of water to accumulate on the floor in the morning. I haven't seen it during the day and the spot dries up with a fan on it. There is even more water on the outside of the coach on the pavement below the slide out with the fridge.
I've taken the outside inspection cover off and there are no leaks there. The white plastic flex hose that feeds a weep drain at the bottom of the slide is broken and I will replace it. With that said, it is dry where the hose is broken. The area is also dry.
Does anyone have any ideas where to begin to look to trace the source of the water? I can only see access from the lower and upper inspection plates outside and they have not helped.
