ksg5000
Jun 10, 2018Explorer II
If the water pump cycles when the faucets are closed - then your leak is associated with plumbing. If the water forms only when it's raining then the leak is associated with roof or window leak. If the water only forms when the air conditioner is running then tighten the 4 bolts that hold the air conditioner to the roof (not too much) - also go up top and make sure the pan under the evaporator coils is properly draining.
