ksg5000
Jun 10, 2018Explorer II
SeminoleFamily wrote:ksg5000 wrote:
If the water pump cycles when the faucets are closed - then your leak is associated with plumbing. If the water forms only when it's raining then the leak is associated with roof or window leak. If the water only forms when the air conditioner is running then tighten the 4 bolts that hold the air conditioner to the roof (not too much) - also go up top and make sure the pan under the evaporator coils is properly draining.
I don't hear the water pump when running the water or when the faucet is off. It hasn't rained. Bolts are tight on the unit upstairs. Could it be the refrigerator or the AC unit behind the couch?
If your connected to shore water then your water pump won't turn on. Disconnect from shore water and then turn on the water pump (leave the faucets closed). Water pump turns on when it senses water pressure reduction .. if you have a slow leak then the water pump will periodically turn on for a second or so.
