2ndhom
Jul 24, 2013Explorer
jannlanz wrote:
Hello,
I have a 2003 Monaco Diplomat motorhome. When I turn on the water pump and take a shower, the carpet gets soaked that is located next to the refrigerator in the dining area - about a 2' section. Can anyone possibly narrow down this problem? I'm wondering what might be involved in fixing this water leak. Thank you so much for any information.
Are you saying it leaks only when using the water pump ...... also when hooked up to shore water supply?
Check see if you have a ice maker water shut off valve from the exterior. If no valve use something to sqeeze off the supply line to determine if that's causing the leak.
