Old-Biscuit
Jul 24, 2013Explorer III
jannlanz wrote:
Yes it only leaks when the water pump is used. No, the RV was not hooked up to shore water supply. Are these lines difficult to replace? Thank you so much for your replies!
If it 'leaks' when using water pump you will have the same leak when connected to shore water supply.....it's all tied together. Same plumbing system.........just two different sources for water.
If it is the fridge ice maker line it would always leak when system is pressurized with water.
IF the leak only occurs when using shower then I would suspect leak has something to do with shower system.....either leaks from shower diverter (downstream of hot/cold water valves) or from shower drain line.
