Hello again, I posted earlier about a strange noise under my rig, I think that is resolved. Thank you for all the help. I now have another issue. At the corner on my bathroom and bedroom the rug is so...
Where does the over flow line come out when you fill the fresh water tank? Mine has 2 over flow lines that drain through the floor to the ground. How do you tell when your fresh water tank is full? Can you see your fresh water tank? the over flow lines should come out the top of the tank. Could be the over flow is draining onto the floor.
