mant's avatar
mant
Water leak
Hello again, I posted earlier about a strange noise under my rig, I think that is resolved. Thank you for all the help. I now have another issue. At the corner on my bathroom and bedroom the rug is soaked. I took a panel off the bottom of the shower and it is soaked under there also. I can't see where it is coming from. We are hooked up to city water, I shut that off to see if the pump cycles with everything off. Any ideas where it could be coming from, it hasn't rained all week. I took the shower valve off the wall thinking it might be there.no, Are all the connections buried in the walls and floor? Is there a way to access them without cutting into walls and floors to check for leaks
  • How about A/C condensation, could it be leaking and traveling?
  • Do you have a washer/dryer? I had a connection loosen behind it once and ended up with wet rug throughout the passenger side of the bedroom.
  • You will have to look up because water always goes down. It cold be a leak as high as the roof and once the water gets there it has no air circulation to allow evaporation. What kind of MH and age helps.
  • Gjac's avatar
    Gjac
    Explorer III
    Mine has an 2 access panels in the bedroom. The lower one allows you to look under the shower pan at the drain connection. The higher one allows you to look at the shower plumbing.
  • its your drain you need to tighten the squeeze nut up.as u stepon thepan water then leaks
