cableguy574ExplorerNov 06, 2018Water LeakI need to remove the right side exterior panel to get to my gray water flex pipe. It is on a 2008 National Pacifica 36A Has anyone done this
Executive45Explorer IIINov 06, 2018If you're talking about the exterior skin, that is usually bonded, (glued) so it most likely will get destroyed trying to remove it....Dennis
Related ContentWater Heater Leak on start up.Water leakLeaking fresh water tankWater PumpFunny water pump leak
