Gunship_Guy
Mar 23, 2014Explorer
smlranger wrote:
Likely culprit is check valve in your water pump. Had that same problem with my previous coach.
Very common. That's where I would start.
Replacing a water pump is easy. But if you want to save yourself some money, you can take the water pump apart and see if something is caught in there. I've worked on pumps for people and have had good results by cleaning grit/sand from inside the pump.
Good luck.
38,780 PostsLatest Activity: Aug 05, 2026
