The_Texan
Mar 23, 2014Explorer
tiredkid wrote:Wrong, water is always present on the input side of the pump. When the diaphragm is leaking, it will flow into the tank. Like I said, it happened to me. My tank overflowed for months, before I figured it out. Once the pump head with a new diaphragm was installed, the overflow stopped. When I opened up the head, the diaphragm had a tear, and the check valve was good.The Texan wrote:
You probably have a bad water pump. When the diaphragm goes bad, it will leak into the fresh water tank. Been there, done that with a Shurflo Extreme 4.0 water pump.
when on city water the water pump is not in play and will not leak water into the fresh water tank no way
38,780 PostsLatest Activity: Aug 05, 2026
