tiredkid
Mar 23, 2014Explorer
steveownby wrote:tiredkid wrote:The Texan wrote:
You probably have a bad water pump. When the diaphragm goes bad, it will leak into the fresh water tank. Been there, done that with a Shurflo Extreme 4.0 water pump.
when on city water the water pump is not in play and will not leak water into the fresh water tank no way
The water pump, although not running, can be the issue due to the fact that the output side of the pump is seeing full shore water pressure. If the check valve fails then that pressure can force water back through the pump and back into the fresh water holding tank.
Ok
38,780 PostsLatest Activity: Aug 05, 2026
