thestarfinder
Mar 23, 2014Explorer
Thanks so much ! Everyone on my post is so informative....I have 2 places to start..Bad pump or 2 way valve......Pump is much easier to get at/out so I will start there....I'll check the diagram and check valve...
Hold everything! while checking on the pump type(it is a sureflo 4.1) between the walls of the bay between the pump and the fresh water tank is a shut off valve!so it is shut off and I'll let it go over night and see if the tank gets water....If not it's the pump, if so it must be the 2 way valve....
Thanks again for the great info,Tom
P.S. I'll post what happens.....
38,780 PostsLatest Activity: Aug 05, 2026
