tiredkid
Mar 23, 2014Explorer
Old-Biscuit wrote:tiredkid wrote:Old-Biscuit wrote:
One of 2 things.......
The valve on water panel can be leaking thru to the 'fill' position and going directly to tank
OR
the pump internal check valve can be leaking thru.
Install a 1/2" in line check valve on pump discharge.....tank stops filling. Problem solved. (Most any RV parts Store will have one)
Tank still filling....then replace the tank/city water valve on panel
why not just plug off the pump out/house in water line and see what happen
Two different lines...........more hassles. Access.
how are they two different lines? one goes in the pump from the water tank and the other lines goes out the other end of the pump
pretty simple in my mind? my water pump is laying right there in the wet bay
38,780 PostsLatest Activity: Aug 05, 2026
