Old-Biscuit
Mar 24, 2014Explorer III
The Texan wrote:Old-Biscuit wrote:Have you inspected his pump or just offering a WAG?thestarfinder wrote:
NO WATER IN TANK this morning ! BAD PUMP(check valve or diafram)....Will replace pump.....Should I go with the shurflo 4.1 or a different brand might be better.....Some posters are saying they had this issue(the pump is like 2 3/4 years old and not used much)....any thoughts ? Tom
PS thanks for the great trouble shooting info guys....
Pump is still good......internal check valve is leaking.
You can replace pump for about $139 (on sale) or for $10 install a Shurflo in-line check valve
Yeah....stopped by last night, tore pump down, inspected it. Check valve damaged. No parts readily available.........hence the in-line check valve :S
38,780 PostsLatest Activity: Aug 05, 2026
