- akahomer1Explorergood to know .just looking to see how cold I can camp with out having to drain
ever thing. - qhorExplorerI also have a 2000 LTV. The water lines are inside the unit and not exposed, so they are difficult to access. The water tank is the only outside exposure but is insulated. As you have probably found where the water pump is under the passenger side rear wheel housing and the winter by-pass valves are under the passenger side of the sofa bed behind the removable panel. That is about all of the water lines you will find exposed except under the sink for the faucets. Not the easiest to trouble shoot, but when they build these things they start with bare walls and everything is built in to fit.
Good luck with whatever you are up to.
Barry - akahomer1Explorerthey were a big help to day. hard to tell if they are under van in the open or all in side
- akahomer1Explorerthey are no help
- midnightsadieExplorer IIheres there phone number 1 204 822 3009.
38,783 PostsLatest Activity: Sep 22, 2026
