bsport's avatar
bsport
water pressure
Loss of water pressure in MH kitchen hot water is good cold water very low. Took off line to faucet and still low pressure, then removed filter and water came out ok but not with a lot of force. Is it the water filter bad, that is what my guess would be, and I was using short filter and went to a long one. Is there a change in filter pressure coming out, of different filters? I m not to smart when it comes to this type of thing. Thanks for any help you can give me in this matter.
BSport
  • Are you sure your cold water supply is not being shared elsewhere such as a fresh water tank fill valve in the wrong position etc etc
  • Look at the pump. Water still goes through it. Might be two lines one to hot water and one for cold water side.
    Pump might have more pressure and force it to the faucet. Unscrew the aerator and see if it comes out. Might have to take the valve out at that water point.
    There is an obstruction, in the cold water side, pipes, since you took off the filter. If you can squeeze the pex pipes you might giggle it down stream whatever it is and then maybe not.
    Any RV Plumbers here?
    Just for the heck ,of it check the fill valve selector. It would seem both sides would be affected if it was only partially in position.
  • Which filter you use makes a big difference in water flow at faucets. Should be no noticeable pressure difference between hot and cold water. May have a restriction in cold water line. Remember pressure is not volume.
  • Probably needs a new filter. The filter itself will cause a little pressure loss.
    Maybe input water pressure is low too.
