Fire_Instructor
May 31, 2016Explorer
Your pump only pulls from the tank. The line between the pump and the city connection is empty (there is a back flow protector that prevents the city water from back pressuring the pump, and into the tank. If you throw about a gallon of water into the tank, it should be enough to fill the pump and that line, then once filled, the pump should shut off. Not a bad way to test your pump,
