mark734ExplorerMar 04, 2014water pump fusei am trying to locate fuse for water pump on 2002 fleetwood southwind workhorse chassis thanks jw thompson
OnaQuestExplorerMar 04, 2014Fleetwood generally puts the pump fuse very close to the pump, in the +12v line, as the ground side is used for the switching (via the Monoplex Controller)
Related ContentWater PumpFuse panel locateWater pumpWater Pump Failure Traveling To The EclipseSlow water/noisy pump
