mark734ExplorerMar 04, 2014water pump fusei am trying to locate fuse for water pump on 2002 fleetwood southwind workhorse chassis thanks jw thompson
ksg5000Explorer IIMar 04, 2014If your pumps not working then defective monoplex controler maybe the culprit. In my rig I ended up hooking up 12 volts directly to pump to determine it was working fine and replaced the controller.
Related ContentWater PumpFuse panel locateWater pumpWater Pump Failure Traveling To The EclipseSlow water/noisy pump
