- HPYHILMExplorerUpdate Found the right fuse it was mislabeled and was bad. Thanks for your responses.
- HPYHILMExplorer
wolfe10 wrote:
Can you turn on the pump from more than one location? If so, you have a relay that powers the pump. Generally found near the pump.
Pump not working from 2 locations, manual states that there is a reset button but nowhere to be found. I know those manuals are kinda generic and are for several models. - wolfe10ExplorerCan you turn on the pump from more than one location? If so, you have a relay that powers the pump. Generally found near the pump.
- DrewEExplorer IIHave you checked the obvious: is the pump switch on? Are the grounds for the pump and the battery solidly connected? Do you have power at the pump control switch(es)?
There must be a fuse or something similar protecting the wiring somewhere. As MountainAir suggests, it very well may not be labeled clearly. - MountainAir05Explorer IIjust check the all the fuses in the panel, Might be hook to hot water heater or any system that has low amp draw. If you have wire tester, then drop the neg cable off battery and no shore power and tone it out.
38,763 PostsLatest Activity: Dec 05, 2025
