Executive45
Feb 17, 2019Explorer III
Leak in the system. Any water UNDER the coach? Most common cause is the inlet valve on tank fill. Second most common is the drain valve being partially open. When was the last time you cleaned the filter?? Perhaps it didn't seal completely. Check the pump for leaks after checking the above two items. Let us know how you make out...Dennis
38,769 PostsLatest Activity: Apr 03, 2026
