goufgators
Feb 17, 2019Explorer
Executive wrote:
Leak in the system. Any water UNDER the coach? Most common cause is the inlet valve on tank fill. Second most common is the drain valve being partially open. When was the last time you cleaned the filter?? Perhaps it didn't seal completely. Check the pump for leaks after checking the above two items. Let us know how you make out...Dennis
Should have done a bit of 'searching' before I posted. Somehow...(?) the cold water valve for the outside shower was ON. The valve's nob had been turned several revolutions...(?). How (?)! The compartment door was locked so not possible for an 'intruder' to have access to the valve. Could it be that we have a 'possessed' MH? Probably not. But, this little mystery will surely go down in the annals of RV mysteries...likely never to be solved :E.
38,769 PostsLatest Activity: Apr 03, 2026
