tommymsw's avatar
tommymsw
Water pump question GPM?
So I have a small class C that I really intend to just use at camp sites. So the water pump will not be needed most of the time. I really only need it to flush the toilet on trips (I think... I have never actually been in an rv before).
My question is.. if I get a well reviewed 1.2GPM pump off Amazon... Will it be enough to flush the toilet?
Also, on the off chance that I want to shower... Will it be TERRIBLE or tolerable. I read that a house shower only uses 2.3GPM so I figure it should be like a weak shower. I am OK with that as I would just be using it in extreme cases.
I figure experience is kind and want to make sure this is not a STUPID idea. Again... I am OK with low pressure for the shower as long as it will at least work? But the main thing is to flush the toilet. :)
  • If you are looking at the ones, for about $29, it does have much pressure. It is only rated at 35 pounds.
    you would be better off with one that is around 50 PSI output.
    Yes, it is a little more money, but you would be happier!
  • Dutch is correct, and I might add the pump pressure is more important than volume in being able to overcome the restrictions.
    60psi is too much, and 35 is about right. I wouldn't go lower.
  • Well, you are partially correct. Just because the pump can pump 3 GPM, or 1.2 GPM is only half the factor. The other half is how big in diameter the water lines are in the camper. Smaller lines will flow less water. So even though a pump may be capable of 1.2 GPM, the lines might be so small it only pumps 1/2 GPM.
    Shower head almost always water saver reducers built into them to prevent the maximum flow, even possible with a 1/2 inch diameter pipe with water behind it. The actual opening in that shower head may be 1/8 inch, restricting the amount of water that can pass through, thus taking longer to run that 1.2 gallons.
    Your toilet just flows water. Whatever the valves the water has to pass through are set for, will really determine how much (or how fast) the water will flow (regardless of pump size).
    So actually, taking a shower, you'll probably not see any difference between a 1.2 or a 3.0, because of the shower head restricting flow. Same is true for the toilet.
    Now, if all your water lines are 1/2 inch (which most are in RV's), you may notice a difference in output at the kitchen sink, as kitchen faucets usually have no restrictions (although some of the newer ones do).
    Hope this helps.
