Fulltimers wrote:
rgatijnet1 wrote:
Besides the obvious problem with the leak, your pump might be noisy because of the way it is mounted. In my coach the pump was mounted directly to the side wall in the basement. When I replaced it I got two braided plastic hose extensions at Home Depot and relocated the pump to a rubber mount on the bottom of the basement compartment. This not only made the pump much easier to service but it also made it so that I could hardly hear it when it was running.
I installed the pump today and it will not shut off. I ran it for a while to purge all air out of the system. No leaks as far as I can tell. I guess I will have to play with the bypass switch adjustment tomorrow to see if I can get it to shut off.
Try running it on city water and open all the valves one at a time to bleed all the air out of the lines then try the pump again to see if it will shut off after it builds pressure.
