Hank_MI
Jun 24, 2015Explorer
DSDP Don wrote:
"dsisemore1".....If you can't get the controller in time, simply disconnect the controller and hook the pump up directly with a quick connect wire. You can then just leave the pump on for the entire trip or turn it on when you get to your campsite.
You don't say where you live....I carry a spare.
Controller on our previous motorhome failed. I made up a small cheater wire to bypass the controller. I kept it in the bay with the controller after installing a new one. Your pump has a built in pressure switch so it will only run when it needs to supply water so bypassing the controller is not a big deal.
38,766 PostsLatest Activity: Jan 10, 2026
