rickvikki's avatar
rickvikki
Water Pump
Hello Everyone:
We have a 2006 Phaeton. Our water pump works then all of a sudden quits working. We found that if we wiggled the fuse it would work for a while but then quit again. Now when we wiggle the fuse it does not work at all, we replaced fuse but still not working. Any suggestions as to what is happening?
Thanks, Vikki and Rick
  • where the fuse is connected to the main wire ,check those connections,s and take the fuse out and clean it, with some steel wool , lot of little things to check before buying a pump.
