Black95Explorer IIDec 09, 2020Water PumpThe 12 volt water pump in my DIY van conversion pumps too fast. Do any of you well versed in electronics know what type of resistor or rheostat I could use to slow the pump down. I was thinking of a...Show More
karlstreamExplorerDec 11, 2020If you think you can slow the pump down by reducing it's voltage, you might try this:LM2596 Buck Step-down Power Converter Module DC 4.0~40 to 1.25-37V LED Voltmeter.It has an adjustment screw to adjust it's output voltage.They go for $3 to $4 bucks on eBay and should be able to handle 1.7 amps. I would get one rated for at least 2 amps.karl
