wa8yxm
May 18, 2015Explorer III
Some do, Some do not.. I suggest you get a Does not.
The place for the pressure regulator is at the PARK END of the water hose.. I have seen parks (Stay in on in fact) that warns you of pressures over 110 PSI and one forum member (not sure which set of forums) claims he's under a lot of pressure here... His gauge shows 125
At those pressures...... Your hose can do a Cartoon Special (Blow up).
PLUS the Sur-Flo regulator they use.. I give it a 9 when new dropping with age (I have one, but it's an external) The Watts and Zurin models I have get a 10 when new and are easily rebuilt.. I think the sur-flo can be rebulit too.
I like the Watts and Zurin mnodels Bell shaped housing, 1/2 inch or largr bore. Mine are both 3/4 inch (Which is often less expensive).
38,782 PostsLatest Activity: Sep 10, 2026
