dougrainer
May 18, 2015Nomad
John & Angela wrote:Sooner Schooner wrote:
I don't use them, I just adjust the water pressure at the water spigot . I just turn the handle until it looks and feels okay.
Good morning. Yah that won't work. If the pressure is 80 PSI on the line and you turn it down till its just dripping out, once the lines are filled and pressured the pressure will be 80 PSI anywhere in the motorhome. Just a heads up.
AND, you are restricting the flow of water to the RV. Doug
38,782 PostsLatest Activity: Sep 10, 2026
